Topic: FIreface UC doesn't appear on system preferences after update
Hi!
I've just updated to OS X 10.15.5 and my Fireface UC isn't available to select as an audio interface on system preferences. It was working fine previously on 10.15.4. Updating the driver did not make any difference and also I checked to have the latest firmware installed.
Any workaround to get the interface working again?
The Fireface USB Settings panel shows me the interface, so it should be recognised, but OS X doesn't let me route the audio through it, it just doesn't appear on the list.
Also the interface isn't available to select on my DAW audio device configuration.
Appreciate any help.
Re: FIreface UC doesn't appear on system preferences after update
Solved!
Catalina asked for permissions for rme driver, but it did not ask to allow it. I had to search and manually allow rme driver permissions.
3
Then you did not read that (Apple) dialog carefully and clicked the wrong button. 'Ok' is intuitive, but in this case wrong.
