Topic: Audio recorded late in ProTools
i've been working with a fireface UC for two weeks, and i'm very impressed so far, specially with totalmix, but yesterday i had a very strange problem and want to know what was the cause to prevent it from happening again.
i was recording an acoustic guitar with two condenser mics. the recorded track was clearly out of time, it was recorded late. it wasn't a playback latency problem as the wave graphic inside the clip was indeed off the grid. the sound was monitored through totalmix without latency. the buffer was at 1024.
i rebooted the pc and the problem was still there. changing the the buffer to 512 solved the issue.
today i opened the same project in order to make some tests, set the buffer to 1024, but i couldn't reproduce the issue
my daw is protools 12.5 (using low latency monitoring), my OS is win 7.
i never had latency in audio recording before even with low quality interfaces. so i don't know what could be the cause to the problem.
Re: Audio recorded late in ProTools
I've sometimes had funky things happen like that, but honestly I'd blame pro tools - I think the Delay Compensation goes wrong occasionally.
yes pro tools is always to blame. haha. i suspect it has something to do with the Delay Compensation too, but honestly never happened this before
