Topic: Matthias / RME Tech support: PCI -> adapter -> PCIe
Searched the forum, found and read related posts/threads, but couldn't find any input from RME on the above mentioned subject, which is what I was really after. Might have overlooked it, if so, sorry for bringing this up again. Hope you'll still find the time to reply : )
I love my two HDSP 9652 cards, been using them since around 2005 I think. Every second they've been up and running, they've been lightning fast and rock solid, with absolutely no exceptions.
As I'll be performing computer hardware upgrades soon that make replacement of the motherboard unavoidable, it would be of great help to know RME's thoughts on the use of HDSP PCI cards in PCIe slots via adapters.
Some 9652 (and other PCI) users report no problems at all, the same performance and stability as when inserted into a PCI slot, while others report that their cards aren't detected by the system, won't show up in the hardware list, aren't recognized etc
Are there differences between the two slots' electrical properties that in some systems become incompatible, while in others they don't? If I remember correctly, the 9652 expects a specific voltage, was it 5 volts? If possible, how does one go about ensuring the correct voltage for the 9652, when inserted into a PCIe slot via an adapter?
If using an adapter, in RME's expert opinion, is a viable solution, might there perhaps be things to look for, and things to look out for, when shopping for a new motherboard?
As mentioned, I'm using two 9652s. I've seen adapters with two PCI slots, inserted into one PCIe slot via an extension cable. Could two 9652s coexist in such a setup, sharing the one PCIe slot/bus?
Worst case scenario, I'll have to shop for 9652 alternatives. In my current system, all ADAT ins and outs are in use. Which other RME gear/setups would facilitate the simultaneous use of six separate ADAT units?
Any and all input will be greatly appreciated.
Hope to hear from you soon
Best regards, Tor
