Topic: Babyface Pro FS with MOTU Micro Express?
Is it possible to use the Babayface Pro FS with a MOTU Micro Express? (a MIDI interface) I would prefer to have all of it running through the Babyface... Can you connect a MIDI Interface to the Babyface? Is there any way to use the two together?
2 (edited by breun 2020-09-06 19:02:05)
Re: Babyface Pro FS with MOTU Micro Express?
The Babyface Pro FS already provides its own MIDI in and out, but if you need more MIDI ports you can add another MIDI interface to your computer. Note that MIDI provides 16 channels per port, so unless you need more than 16 channels you could also do it all via the MIDI ports on the Babyface.
