Topic: ARC USB extension
I'm having questions on how to connect an ARC USB that is 20m away from the computer:
- Does the ARC USB work properly if connected to a simple USB hub (same as keyboard and mouse) ?
- Does it work over an USB over ethernet extension (Aten HDMI/USB, with powered receiver) ?
Re: ARC USB extension
I would say yes to both, although I haven't tested the second one. USB 1.1 is so easy from today's viewpoint, and the ARC USB doesn't need much power either.
Thanks! it works perfectly on the hub.
