1 (edited by karoloydi 2020-09-19 21:29:33)
Topic: Route Analog 1&2 to Output 2&4 in TotalMix
I have a 4 speaker surround setup at home with Multiface/PCIe card.
I bought a digital piano which is located on the right side of my desk. (between the right speaker and the right surround speaker)
Basically I want to route what is supposed to play on left speaker to the right speaker and what's supposed top play on the right speaker to the right surround speaker. (for when I play VST piano instruments)
I can't figure out how to route what is supposed to play on left speaker to the right speaker.
(Well, I can if I keep unplugging and plugging in cables, but that's not very practical)
Any suggestions? or any alternative software I can use to do that if it is not possible from Totalmix?
Re: Route Analog 1&2 to Output 2&4 in TotalMix
Are we talking stereo sources? Then use the Width knob to reverse the channels.
@Karoloydi
Or select those outputs directly from your DAW!
Set the input mono. you get 2 channels then which you can route and pan freely
Thanks for your replies.
I have a lot of options now.
I think the DAW option is the easiest. I'll use the surround panner to do the job.
