Topic: What Do You Do With TotalMix?
Sincere question.  It seems like a dynamite app, but I can’t find a use for many of its features, other than basic routing.  It’s less full-featured than a DAW mixer, but also doesn’t have comprehensive enough  remote control to the the back-end of a full mixer surface.  I’d love to use it that way...
Earnestly,
Brian
Re: What Do You Do With TotalMix?
I personally use it with my Babyface Pro to monitor without latency and with some reverb while recording. Monitoring through software (DAW) adds noticeable latency. But I bet there are a lot more advanced use cases.
What is TotalMix FX ? -> https://www.rme-usa.com/totalmix-fx.html
A full collection of tutorial Videos in my blog (new and very good older videos, that shouldnt get lost):
https://www.tonstudio-forum.de/blog/ind … al-Videos/
Some of my use cases with UFX+ / ADI-2 Pro FS R BE / Octamic XTC: https://www.tonstudio-forum.de/blog/ind … Rec-EN-DE/
Snapshot of the complete setup with a hook to HiFi to use it as 2nd monitor pair: https://www.tonstudio-forum.de/blog/ind … her-EN-DE/
In other words .. where other vendors sometimes develop their monitoring/mixing software completely new for a new series of devices (device-/project-oriented approach), RME designed TotalMix FX to be superior from ground up and decided to use only this one software for ALL of its devices in the last 20+ years.
By this the product reached a high stability, maturity coupled with great functionality and absolutely no lag.
TotalMix FX has been designed to be the best monitor mixer for recording interfaces with many comfort functions to quickly create, store and recall mixes for monitors, phones, outboard devices plus well thought other features.
Other functions are i.e.
- enabling for zero latency mixes on the device
- loopback recording
- setting / controlling fader groups
- controlling the FX section (supported by some recording interfaces with FX chip on board)
- controlling DURec for UFX *
- the interfacing between ARC USB and recording interfaces which support TotalMix FX. By this even around 20y old devices got now a remote for the TM FX control room, for which initially no remote was planned.
- AUXDEVICE support, remote control feature for Octamic XTC
- configuration of MIDI over MADI
- new remote version of TM -> TM FX Remote to be able to control TM FX from remote computers over network
- Snapshot and Workgroup support
- Workspace Quick Select support
- Quick recall of other Quick Select workspaces by ALT-1, ALT-2, by this you can get more than 8 Snapshot places to save routings / settings
Using it as a flexible OSC controlled digital live mixer and recorder (in combination with some hardware de-essers). It’s doing a pretty decent job, though it would be great to have some more sophisticated dsp (especially soft knee control on the compressor, faster attack / limiter, more bands on the EQ).
Old post but... in addition to saving routing presets for quick recall, as a theatre sound designer I find total mix really useful for monitoring multiple output shows through a single pair of headphones when working away from the show and full outputs aren't available. Allows me to hear everything very easily without making any changes in the actual show file.  I've also used it on tour in theatres that have less speakers available - again the show can be very quickly routed to fit the available system without having to change anything in the show.
Beside other things, I use TM together with Digiface USB as intelligent ADAT patchbay. I use few digital effect processors and may easily route signals to them and between them. Just by loading preprepared snapshot the routing (effects used, order of effects, signal(s) to be processed by effects...) may be radically changed.
It's simply fantastic in handling.
If I try something new or to help somebody in the forum and even reset TotalMix FX completely.
All that I have to do to bring everything into the prior state is to recall my Workspace from Quick Workspace select with ALT-1.
In addition to saving workspaces as a file to your computer it gives you 30 slots which you can quickly access from TM FX.
And the first eight slots can be accessed very rapidly by ALT-<1..8>.
The eight TM FX Snapshots / routings allow me to switch between 8 entirely different use cases and
automatically restore all needed settings (gain, submixes, loopback).
In addition, the Matrix gives a complete overview over all submixes at once.
In the normal submix orientated view you get the submix of the selected HW output.
You can see the submix according to the fader position in top and middle row (HW inputs, SW playbacks (audio from PC)).
Of additional help is the small button "Sub" which only shows those channels that route audio to the output.
But everything according to this one HW output.
Matrix view shows you on the "x-axis" all HW outputs.
And what you see in mixer view usually in top and middle row, you see now in a vertical orientation.
Therefore you have here a complete overview of your routing for all HW outputs.
Additionally useful are two additional functions, you can
- hide not needed channels in "Channel Layout" which is applicable for all snapshots
- store up to six of such "Channel Layouts" for showing most important channels of a device or for a certain use case
Both in combination gives you a phantastic overview in mixer and matrix mode.
To get an even better overview you start a setup best from scratch and delete all routings quickly in matrix mode
and implement only the needed routing for e.g. monitoring and what is additionally needed.
This gives then the best overview in mixer and especially in matrix view if you only see those things that are really needed.
After that you have also a much better understanding about routing in general and TotalMix FX's logic.
At the end it boils down, to two simple things
- Audio Signals coming in from devices that are connected to your inputs
- Audio Signals coming from the PC
Due to TM FX's logic design you can decide for every HW output whether you want the audio signal
- from the HW input with the lowest (near-zero) latency or
- from the PC with higher latency which depends on buffer settings and whether you have full RTL or half of it
  full if the signal came from a HW input, half if the signal originated on the PC (e.g. from a virtual instrument)
I do not know any other mixer software which presents this topic in such a clear, logic way
and offering so many useful functions for operation and which works flawlessly.
9 (edited by Muffin 2024-10-03 14:56:17)
One very nice thing about TotalMix is that I can use the Echo FX for lip sync during video calls on my UCX II while monitoring in real time. That was a trick I read about on this forum and I believe I got it from MC.
The new Room EQ has a too short a delay as I need 200 ms for the lip sync. The Echo delay steps are in 10 ms but good enough for my use.
