Topic: Getting a surround signal from Cubase to my speakers when using a UCX?
Hi there,
I've been trying to get a 5.1 setup to work in Cubase in combination with my UCX.
In Cubase, in the Audio Connections window, I've created a 5.1 output. The left/right/center/lfe/left surround/right surround channels have been routed to the corresponding output on the UCX.
However, I'm only hearing sound that is panned left and right, routed to the Analog 1 & Analog 2 outputs.
Is there something that I should change in Totalmix FX? Iv'e got it set to DAW mode, but that did not help.
Any help would be greatly appreciated!
Re: Getting a surround signal from Cubase to my speakers when using a UCX?
In DAW mode, TotalMix does not have any routing or matrix capability, so the error must some from the Cubase side. Please double check your setup there.
