Topic: Driver/Firmware update not working, Babyface Pro FS not detected
I have a Macbook Pro from early 2011 with Mac Os Sierra 10.12.6 on a 2,7 Ghz Intel Core i7.
I just bought an RME Babyface Pro FS and proceeded to install the driver and flash update.
I restarted the computer.
Total Mix and Fireface USB Settings appear in the Apllications folder.
Then I connected the Babyface through USB.
Neither Total Mix nor Fireface USB Settings launch.
I double-clicked on RME USB Series Flash Tool but it doesn't launch either.
I followed the procedure in case the Babyface was in Class Compliance mode but nothing changed.
I am not sure I understand correctly how to know if it actually is in CC mode or normal mode though. Manual says the letters “CC” or “PC” should appear on the level meters but I don't see any of those. The first time I tried the procedure (hold SELECT and DIM button and then plug the Babyface), 2 red lights appeared on at the bottom of the OUTPUT level meter (just above “DIM”), which were not there when I first plugged the Babyface.
When I tried to launch the Total Mix app, it seemed to launch because it appears in the Dock, but nothing else happens. When I click File → New Total Mix Window, the Function & Device Select Window appears, but the Babyface doesn't appear in the Device Selection part.
I also tried the same things after downloading the older driver. No success either.
Does anyone know what the problem is?
