1 (edited by fieldstu 2020-11-07 01:21:48)
Topic: Digiface USB sample rate internal vs external question
Digiface USB is set up in TotalMix so that it routes Optical 1 input to Optical 1 output.
Settings are so that Clock Source = Optical 1 clock the Digiface to the incoming sample rate of 48kHz.
Now when setting back Fireface USB Settings to Clock Source = Internal; Sample Rate = 44100 Hz, I see Input Status Optical 1 = Lock, Sync, Lock, Sync etc.
I was expecting also that the sound would become garbled somehow, but actually it keeps sounding all right.
How does this work?
ADI2, Digiface, ARC
Re: Digiface USB sample rate internal vs external question
Record a simple sine wave and you should see the sample errors. These are not always audible and often it is just one sample not correct when the display changes to Lock.
Thanks Matthias. This answers my question.
ADI2, Digiface, ARC
