Topic: HDSPe AIO sync questions
I am hoping to get confirmation that I understand syncing devices correctly..
If I were to use external and separate AD & DA converters with my HDSPe AIO, the AD converter will transmit word clock via AES to the AIO. The DA will then receive word clock via AES from the AIO. Are there any settings that need to be changed in this scenario? Will the AIO simply pass the word clock received from the AD converter to the DA?
I would have the same questions for using a combined AD/DA converter like the ADI-2 Pro. Would there be any change to settings in the AIO or is it just plug and play?
David
