Topic: Balanced to Unbalanced Connections
In the Babyface Pro FS manual it states:
The short circuit protected, low impedance XLR line outputs do not operate servo balanced! When connecting unbalanced equipment, make sure pin 3 of the XLR output is not
connected. A connection to ground might cause a decreased THD (higher distortion) and
increased power consumption!
So you suggest using pins 1&2
But looking at decent transformer converters they tend to use Pins 2&3.
This is Canford Audio in the UK:https://www.canford.co.uk/Products/2125 … ono-female
And this is Neutrik's own:https://www.neutrik.co.uk/product/na2m-d0b-tx
Is the RME output non-standard or am I misunderstanding something ?
