Topic: UCX : unable to flash or display TotalMix window on macbook16 catalina
Hello
I searched a lot and did not found anything related to my problem,
Setup is : macbook pro 16" (catalina) with fireface UCX in USB with a usb-c hub
I installed latest drivers & TotalMix software, reboot, everything seems OK
When I lunch the RME totalmix app, the "title bar" is updated with the menu from the Totalmix software, I can access to the Preferences but I can't see the usual control window that we use to control the UCX.
Same for Firmware update, it sees the UCX but clicking the Update button does nothing (no error or anything)
To be sure, I installed latest driver + totalmix on Windows 10 => everything OK, totalmix window appears and I can control volume/EQ etc
I successfully flashed with the latest FW version on windows 10
But still not working on the Mac
Here is a screenshot with some informations,
Thank you by advance for your help!!
Best regard,
Harold
