Topic: Totalfx Routing for Hardware.
Hi guys, i am new here and also new to RME products. I recently bought a Babyface Pro which sounds great and i am really pleased with it. Having said that i am struggling a little bit with Totalfx. What i am trying to achieve is, i want to connect my 500 series outboard gear but for the life of me can't get it working.
Bear with me here, so my signal chain is, Babyface Pro is linked via ADAT to the Behringer ADA8200. I then connect my Radial Cube to the Behringer as follows. Input from the 500 series goes out into the output 5 of Behringer and then the output from the 500 series back to input 5 of the Behringer. I think that's the correct routing but i am not so technically inclined so i could be wrong. Then i select the same in my Daw which is Reaper. I selected ADAT 5 don't get any signal coming in. Anyone have any advice for me. I am thinking my problem lies within the Totalfx software. I should mention i have ADAT 5 volume in Totalfx engaged.
Thanks in advance for any help guys.
