Topic: Messing around with Totalmix
Setup : MacBook Air M1 , Babyface Silver and a ADAT
The Babyface firmware is up to date, latest Driver is installed.
The system works fine.
But when the ADAT is connected things are wired inside Totalmix !
The input channels ADAT 1/2 are not there.
Instead of ADAT1 or 2 there is AN1/2.
The signals from the AdAT-unit arrives the Totalmix correctly but in the Computer the DAWs get it wrong.
ADAT mic 1 is available as input 3 !
And so on, every ADAT channel is shifted two steps, in every DAW I tested.
I just want to record a bunch of mics into Logic.
I would like to have those mics in correct place on the matching Input Number.
I would like to see ADAT 1/2 input channels inside Totalmix.
What stands AN and AS for ?
I did reset the Totalmix to the simplest option.
The ADAT-unit is not an RME, I borrowed it from a friend and there in his studio it works well.
The connection of the ADAT was ok, I know this sync configurations well.
Everything is set to 44.1 kHz !
I think there might be a problem in the new USB driver for M1-Macs ?
I am very sorry for not having enough money at the moment for a new Babyface Pro and an Octamic ll, it's on my wish list.
Thank you very much for support in any case, hints tips ideas etc.
