Topic: Periodic pops from Digiface USB's ADAT output?
Hello
I just received my new Digiface USB and was really excited to test this. However, it was really disappointing.
My setting is:
Windows 10 Pro 64bit
Digiface USB
Focusrite Scarlett 18i8 2nd gen
I have been using 18i8 for years without an issue. The buffer size is 64 and never had an issue.
Digiface's 2nd ADAT output is connected to the ADAT input of 18i8 via an optical cable. That's the only connection between the two. Digiface's Clock Source is set Internal. 18i8's Clock Source is set ADAT. The sample rates of both are set to 48khz.
The speakers are connected to 18i8's monitor outputs. In the Focusrite Control, ADAT 1-2, 3-4, 5-6 are added and they are directly connected to the Monitor Outputs 1-2.
Now I'm not playing anything from the OS. Waiting in silence for a while and I can start to hear pop noise from ADAT 2, 3-4, and 5-6, except ADAT 1 only. The meter indicated -0.6 dbfs noise came in. It seems somewhat periodic. Once in a couple of minutes.
The TotalMix shows there was no such signal sent through the hardware output. But Focusrite Control shows the pop signal received by the meter.
I tried various buffer sizes' of Digiface : 64, 128 and 256. All the same.
Sometimes, after booting, there is almost a periodic pop noise coming every second or so.
Have a look at the screen recording:
When this happens, all the audio play makes continous crackling noise.
What am i missing here? This is my day one of my first RME product, and I had a great expectation.
BTW, I found a line from the manual that says "All devices connected to the Digiface USB must be properly configured for Full Duplex operation." What does it mean? Can it be somehow related to this?
