Topic: Clipping noise from digiface when changing the sample rate
Hi
When I change the sample rate from 48k to 44.1k for example in digiface, it outputs clipping/popping noise at 0dbfs to its all ADAT outputs even when the fader is muted in the totalmix. You cannot observe the noise from the totalmix, but only at the side of ADAT receiving device. It happens once when I change the sample rate. BTW, the digiface is using internal clock source.
The noise is very annoying when ADAT out is connected to a speaker.
It doesn't show any other problems though.
Is this normal?
