Topic: RME FF UFX+ to send sound to ADAT
Dear Friends!
I need to send a soundmix from FF UFX+ to my Denon receiver via Toslink optical cable connected to ADAT2 out.
In the TotalMix (and on the UFX+ display I can see that the sound goes to all my ADAT out channels (1-16) but I can's hear the sound on the connected Denon (toslink optical input)
Can you please explain how to send a sound from any adat to another device by toslink (among those 16 adat channels)? How to choose those channels properly?
I have got RME FF800 and there I have connected a digital out to Denon by means of COAX cable (SPDIF) and that worked pretty nice for years. But UFX+ has only got two adat interfaces.
Andy
Re: RME FF UFX+ to send sound to ADAT
Try this :
In the USB settings of the UFX there it should be possible to switch the adat out adat or spdif.
Choose SPDIF and try.
side note: if you use ADAT2 with ADAT protocol, then ADAT2 and AES are two completely separate ports on UFX *
which means you have two different submixes.
If you run ADAT2 with SPDIF protocol, then ADAT2 and AES port are together / bridged.
I only tell this, just for the case you need to use the AES port for other things.
Dear Friends!
Thank you very much for your support.
I have done what you've recommended and all is working!!!!
Best Regards
