paulnajar wrote:[...]
Ramses according to your own tests the RayDat had slightly better rtl than HDSPe Madi FX on your windows machine but UFX+ had the best when converter latency was added in.
Hi Paul, 1st of all congrads that you found a nice solution.
One thing, don't know exactly how you came to that, the HDSPe MADI FX has an even (slightly) better RTL value.
HDSPe MADI FX 2,15ms
vs RayDAT 2,29ms
BTW, the advantages of an HDSPe MADI FX:
- 3 MADI busses, MADI routing
- resource optimizing ASIO driver: instead of instantly transferring all (!) channels between PC and recording interface
only groups of 8 ports are activated in the driver if at least one port of such a "group of 8" is active
- redundancy options which can also be used to mirror a MADI bus for e.g. backup recordings with DURec as disk recorder
- AES i/o, ideal for integration of e.g. ADI-2 Pro FS R BE into the setup
- MIDI i/o
- the only PCI/PCIe card with FX chip on board
Did you check also this review that I did some time ago? https://www.tonstudio-forum.de/blog/ind … Pro-FS-BE/
Link to the review text in PDF format: https://www.tonstudio-forum.de/index.ph … l-v1-1-pdf
But ok .. if you only need 1 MADI bus, then the UFX+ might be the most flexible solution offering even mobility and the possibility to connect towards PC/Apple using USB3 and Thunderbolt (even USB2 is possible without MADI) and
Autoset, DURec, AES, 2x ADAT (1x SPDIF), 2x MIDI, fully operateable in standalone mode via display, ARC USB port for standalone operation.
Whether 1 MADI bus is sufficient will also depend on whether you work mostly in single or double speed and how many devices you need to connect.
