Topic: Digiface usb word clock problems sudden onset
I am running Focusrite LS 56 into adat 1
                    UA 4-710d into adat 2
                    Audient asp 800 into adat 3
coax cables from Focusrite-UA-Audient to carry clock
it was all running well until I installed Colibri to play .flac and .dsd files
when Colibri is launched, it changes the sample rate and then the system will no longer work.  I have tried every possible connection and master/slave combination I can think of but nothing seems to get anything locked.
Please help, I am at a standstill with clients in the studio.
Mac OS 10.15.4
2 (edited by waedi 2021-04-06 19:14:48)
Re: Digiface usb word clock problems sudden onset
Is it possible to set the sample rate in the USB Fireface settings to that sample rate witch the colibri want to use ?
Is the interface working with this sample rate ?
Have you tested with disabled "auto sample rate switching" in the Colibri configuration ?
From the Colibri website:
macOS Big Sur update is out in a few days
