Not sure what you expect from this thread, I would simply use what works best, the ASIO driver.
Would that alone solve the issue for you ?
Thanks for giving some information, but you didn't tell anything about your system.
What system do you have ? A Laptop or a Desktop System ? CPU, RAM, Mainboard, SSD or Harddisk ?
Other recommendations and questions:
- Using an ASIO buffersize of 512 or 1024 sounds reasonable, but did you also try 2048 ?
- How is the system load in such situations where you have audio instabilities ?
- Can you deactivate LAN, WLAN, Bluetooth, internal soundcard to see whether problems might come from there ?
- What Windows Energy Profile are you using ?
My personal experiences with audio players under Windows 10:
I am using ASIO for MusicBee (my main player) and foobar2000. Last year I asked Steven Mayall, the MusicBee owner, to fix an issue that playback with content of different sample rate could not be played back successfully. Since this is fixed I am very satisfied to use MusicBee with RME ASIO driver. Maybe this could also be an option for you. But also foobar2000 works well with ASIO on a last recent Windows 10 Pro 20H2 installation.
Sometimes I also experience audio drops when using the network, as the network driver seems to issue a lot of DPCs.
Changing the network driver from Microsoft to Intel for my i350 (v26.2) chip brought more stability.
The following information should only be used for desktop system which have better cooling compared to laptops.
But still it seems to be advises to use - at least for my system - to use the energy profile "High Power".
Best results I achieved using Process Lasso Pro where I can use some additional features that are very practical, like e.g.:
- automatic switching to Energy Saving if the system is idle for 30s (configurable), feature IDLE saver
- automatic switching of Energy Profile based on the application, with the possibility to bypass IDLE saver for certain apps
- pinning of application to CPU cores
My default Energy Profile is now a modified (*) version of Energy Profile "Balanced":
Setting Core Frequency to 80% = 2.9 GHz and disabling CPU core parking.
(*) you can modify energy profiles by using "Park Control" from Bitsum and also disable cpu core parking with it. But careful when tweaking. Make photos / screenshots 1st before manipulating. And always take care, there are settings for AC and DC (battery) operation. Always check CPU temperatures under load esp. with laptops. Too much heat can result in additional noise and that the system throttles automatically CPU clock or that you get an alternation of clock speeds which you need to avoid, especially for recording we want a stable CPU clock.
As soon as I start MusicBee it does several things:
- automatically sets application power profile "Bitsum High Performace" (Bitsums modified version of "High Power")
- sets CPU priority to "high"
- sets CPU affinity to all but the first (of 6) cores, because the 1st core always has the highest number of DPC counts
- sets I/O priority to high (as it also accesses disk and network sometimes, to be on the safe side, not sure if really needed)
- induces so called "Performance mode" which prevents that IDLE saver becomes active even if system is IDLE.
BTW: I set up Process Lasso Pro, that the core engine is being startted as a service, so that you can control more processes compared to starting it up as user.
Nice in this setup is the automatic switching of Energy Profiles and priorization based on system state and which application I start with the possibility to disable the IDLE saver for some application, so that a Music Player or backup can run at highest Prio even if I am not active on the system = the system is IDLE.
But still there are situations when playing back Music with MusicBee where I get a short audio glitch although the ASIO buffersize has been set to safe 512 buffers and the CPU load on the system is under 5%.
Its difficult to say whats causing this, I assume that there are still issues with the application MusicBee, as I never had an audio drop with Cubase.
Final warning: do not tweak too much with Process Lasso Pro not to screw up your system. Some people even say that lowering prio for certain processes can lead to better result instead of hoping that a priorization does the trick. It's not an easy topic.
