Topic: ADAT output mirroring in UFX+ Class Compliant mode?
Hi everyone, having an issue with my iPad and the UFX+ and reading the manual addendum for CC mode has not really helped me.  I have successfully entered CC mode and I can see signal from the iPad being sent to Analog Outs 1 & 2.
However in my studio I have a Lynx Hilo as my main DAC connected to the ADAT outs of the UFX+.  I cannot figure out how to enable mirroring like the manual says to that software playback channel 1/2 from the iPad is also sent to the ADAT outs.  I tried both CC Routing modes 24 channel and phones, with no luck.
Any ideas on what I could be missing?
Tarekith
http://tarekith.com
Re: ADAT output mirroring in UFX+ Class Compliant mode?
As you have an iPad invest the small amount of money, buy TotalMix FX for iPad - and all routing issues will be over...
3 (edited by Tarekith 2021-05-29 00:53:21)
Doh, I had Totalmix Remote and forgot that there was another iOS app fopr controlling the UFX+. All sorted and working fine now, thanks very much for the suggestion.
Quick question though, if I set the Interface Mode to Automatic, will it switch to CC mode when only an iPad is connected?  Or do I need to always set the UFX+ to CC mode manually from the front panel before connecting any iOS devices?
Tarekith
http://tarekith.com
It is not possible for the UFX+ to differ between USB and CC, so you have to set it manually.
