Topic: Fireface UFX " EQ+D for Record" strange behaviour/issue
Every time I startup/Restart my computer, I have to check/uncheck this option on the USB Settings panel in order for the levels in my daw match the levels on Totalmix. It seems that, even if deactivated, every time I reboot my computer, the levels on my daw seem to carry this option activated, as soon as I check/uncheck that box, the levels resume to match tho ones on Totalmix.
Here s my Totalmix setup: Mic Ins 9/10 receive a Sphere L22, then I created a mute group with the fader up on those channels that I unmute for Listenback purposes, I have dynamics on those channels in order to have better listenback levels when not monitoring through the daw, this is a daw issue, its a workaround I had to do. Thing is, I have the " EQ+D for Record" disabled, only activates when I unmute that group, but it seems that this option is not working like intended, seems like, even tho the box is unchecked, upon a computer restart, it behaves like it is indeed checked.
Latest drivers and Soft versions installed,
Sphere L22----Fireface UFX----Mac Pro 2012 ( Mojave latest release ) ----Nuendo 11 ( tested whitout Plugins )
Would appreciate a reply,
Thanks.
Re: Fireface UFX " EQ+D for Record" strange behaviour/issue
Driver version and version of TM FX used? Firmware version of UFX?
TotalMix fx version 1.72
Firmware V.360.  Driver V.3.20.
We tested with driver 3.20 on Mac OS 10.14.6 and UFX v360, Mic channel 9 with EQ and Dynamics working. After reboot that EQ+D for Record state is exactly like it should be (active/not active). We also think that such an error, that affects recordings for everyone, would have been reported earlier already.
You could send us your workspace so we can have a look again, but maybe this has to do with your Listenback workaround?
Hi Matthias,
I cannot replicate the issue again also, but it persists.
Ill keep in touch if I find anything more concrete.
Thanks again for the reply.
Miguel Duarte.
Hi Matthias,
It happen again, this been happening for over 6 months as far as I can remember.
The Fireface usb settings are not set as login item, but they never were and I don't remember this issue at all during the 10 years I have the UFX. Thats a voiceover template in Nuendo, just opened without any config changes, as soon as I open the Fireface USB Settings, the levels go to normal status. Tried with the USB settings on and out of the login items, it doesn't make a difference, it doesn't happen all the time tho.
Would appreciate any kind of input, even if this is not an RME issue.
Thanks,
Miguel Duarte.
https://imgur.com/a/Vk4Wgd8
