Topic: Thunderbolt Firmware
Hi.  So I run my UFX+ via USB on my iMac.  I was running firmware 53 with drivers 3.25 with no issues.  Today I accidentally updated the firmware to revision 54, from the HDSP(e) Thunderbolt download section.  I don't have thunderbolt cable, I run via USB.   Now the iMac does not recognize the UFX.  Ive tried resetting to factory, switching USB ports, restarting, reinstalling USB drivers, but nothing helps.  When I open the Flash Update Tool and click flash nothing happens.  Totalmix and the USB Setting app are also non responsive.  Is there a way to revert back to firmware 53??  All this happened after I did the update.  Thanks for the help.
BTW, iMac uses Intel, not M1 chip.  It has 4 USB 3 ports and 2 USB-C ports.
Re: Thunderbolt Firmware
https://forum.rme-audio.de/viewtopic.ph … 70#p170270
It’s ok. I’ll look into any possible solution, Mac or PC. Appreciate the responses.
4 (edited by ramses 2021-06-30 05:24:35)
You tried already all USB3 ports on the iMAC and a different USB3 cable ?
Did you check on the UFX+ the settings of
      Setup -> Options -> Interface Mode -> default: Auto
Maybe try a fix setting of USB3. For switching this setting you need to unplug USB cable, after that replug.
I only have 1 usb 3 cable, so I have to order another one. I did order a thunderbolt to usb-c cable to see if that works. I’ll try the settings to auto to see if that helps. I did try several ports on the iMac but no change.
6 (edited by ramses 2021-06-30 05:29:58)
Do you have an external USB3 Harddisk / SSD ?
Maybe you can check the proper operation of that cable using such a device.
I assume it's the standard RME 1,8m USB3 cable ?
Just checked. It’s set to auto.
8 (edited by headclouds 2021-06-30 05:48:01)
Ramses, unfortunately my SSDs are in a usb-c dock. Fire face is using the standard rme usb 3 cable.
BTW, you can also use an USB2 cable. I just checked that. Works here without any issue, just flashed through USB2 in interface mode auto.
10
You did not mention your OS. If Big Sur it looks like this one:
https://forum.rme-audio.de/viewtopic.php?id=33277
Using Thunderbolt might still work - different driver and system response.
Ramses, I tried your suggesting but also failed to recognize.
MC, that solved the problem!  Thank you very much.  It was the permission.  I must've rebooted before it fully installed and given install permission. Thank you everyone for you help and suggestions.
