Topic: Gotomeeting - distorted sound (Babyface Pro - Windows 10)
Under Windows with Gotomeeting I have distorted sound when trying to use _any_ of the Babyface outputs available.
The built in Realtek sound driver works without a problem. The Babyface outputs also work with other programs (Zoom, Teams, foobar ...).
Are others experiencing the same problem with Gotomeeting (you can download and make a test call to check the audio setting: https://support.goto.com/meeting/help/d … -g2m010002 )?
Any solutions to solve that problem?
EDIT: Similar to the thread "Babyface Pro FS - Probleme (knistern / knattern)" (https://forum.rme-audio.de/viewtopic.php?id=33138) the audio output is not at the right speed.
The Realtek audio driver plays at the correct speed, while the Babyface output plays at about (or possibly exactly -- but that I can not say for sure) a factor of 1.5 too slow.
In contrast to the problems desribed in the other thread _no_ changes have been made to the buffer size at all (is set to 128 and has been unchanged after reboot also.)
