Re: Babyface Pro FS - Probleme (knistern / knattern)
Changing the buffer size is the same as sample rate - it is not supported in real-time with WDM, and some ASIO apps also fail with that.
RME User Forum → FireWire & USB series → Babyface Pro FS - Probleme (knistern / knattern)
Thanks for the clarification. Would be really great to add that to the manual / problem or Windows section. That would have saved me maaaany hours of researching, testing, reporting and so on...
Real-time means here:
a) while the application is open
b) while the application is not only open, but also outputting an audio stream ?
