Pages 1
RME User Forum → FireWire & USB series → After update to Big Sur, Left/right different output level
Please check the cables, the difference for Balanced vs Unbalanced is 6dB.
the cables are balanced.
everything worked great before the update.
Have you checked if there isn't a "balance" control in System preferences/Sound?
I've only seen this kind of problem once after an update, and it was with internal audio. Never found a solution and the user was happy correcting it with the balance control.
Obviously, the user wasn't an audiophile
I only see an imbalance at the optical digital input here....
