Topic: Signal Path for Direct Routing
I'm hoping someone could describe the signal path that my BFP-FS and UCX II use when I route, for example, AN1 In to AN1 Out in TotalMix.
I'm doing some timing tests, and it appears (unless I botched my testing setup, which often happens), that the AD and AD are completely bypassed. My timings are coming in at wayyy below the cost of a round-trip through the converters (like 0.3ms rather than around 3.7msec at 48samp/44.1kHz). Is there some Analog-to-analog link going on??
WindSynth:Sylphyo Cantabile Ableton Push3S
