Topic: HDSpe MADI Connections
Quite new in this word of pro audio, and I have a newbie question for you...
Is it possible to directly connect 2 Hdspe cards via MADI (Transmit of one plugged into Receive on the other one), or is it something completely against nature? :-)
Many thanks for your help,
440Hz
2 (edited by waedi 2021-12-08 00:41:56)
Re: HDSpe MADI Connections
No problem.
Settings in one card, clock source internal.
Setting in the other card clock source external Madi optical or coaxial depending on the cable you use.
Both computers use their own card and Totalmix, you can transmit and receive digital audio between each other.
3 (edited by 440hz 2021-12-08 16:37:17)
No problem.
Many tx for your answer....
