Topic: Babyface Pro Fs CC Mode Direct Monitoring
Hello fellows,
is it possible to direct monitor a mic-signal on Analog Input 1 so i can hear the signal on both left and right headphone shells and not only "panned" hard to left?
Thanks for help
Manu
Re: Babyface Pro Fs CC Mode Direct Monitoring
Change the input channel to mono, then use Panorama.
Thanks for the reply but is that also possible with the hardware buttons and without the use of the totalmix software? In CC Mode theres no way to control the hardware with the totalmix software? Am i right?
Thanks for help
Manu
If you use iOS then there is TotalMix. Else you are right, routing pan is not adjustable from the restricted user interface controls on the unit.
Thanks for the reply but thats really sad to hear that there is no way to center a direct monitored mono signal without TotalMix sad
Thanks for help
Manu
