Topic: UFX+ shorted cable caused MIC/LINE input not work
I use a 48v mic in MIC/LINE input 9 on UFX+, today I drag mic's cable then the sound card create big clip sound, and I found that it was caused by the cable is chewed by my cat.
After replace cable,I found that MIC 9 is totally silent ,even not work as a line input, but the 48v power is still worked, I check all other input, they all works fine.
So what is most probably happend in my UFX+?
If it is a hardware falut, as it is out of warrenty(and the sercurity sticker was scrashed by friction), how much need I pay for get it repaired?
Re: UFX+ shorted cable caused MIC/LINE input not work
https://forum.rme-audio.de/viewtopic.ph … 44#p180344
