Topic: AVB-Tool PHY Problems :(
Hello the PHY in the device does not work satisfactorily with long cables. Example:
Digiface AVB < 80m Klotz RC5 > AVB Tool . If the link is unstable, as soon as you shake the RJ45, the values become so bad that there are dropouts and the link is lost. This is very unsatisfactory! It's not the cable, Dante devices don't have a problem. I have already fed the clock externally, you only have to push the Digiface AVB over the table and the connection is already disrupted. A Marvell Switch will not link with the AVB tool. Other devices do not exhibit this behavior!
