1 (edited by Manaberry 2022-01-27 10:56:00)
Topic: [SOLVED] macOS driver won't start at launch
No matter how hard I try to make my Digiface USB recognize on startup, nothing works. The only way I can use the interface is to reinstall the driver and at the end of the installation process, something is triggered and the card is working.
macOS 11.6
RME driver 327
What that's shadow magic?
Re: [SOLVED] macOS driver won't start at launch
You will need to use the workaround of resetting the kext consent list to make the driver load between restarts again, see: https://forum.rme-audio.de/viewtopic.ph … 82#p171782
3 (edited by Manaberry 2022-01-27 10:45:39)
You, my friend, just saved my life!
I also had to remove the extension prior to reinstalling properly the driver. It's working great not on reboot!
Thank you!
