51 (edited by Johannes AU 2022-02-02 17:09:45)
Re: RME sur Bloc de puissance
ericcholley63 wrote:
yes I unzip it and then execute
Did you correctly installed the driver? It should go through an installation process, e.g. ask you to agree the terms of licence.
https://rme-audio.de/downloads/driver_m … _09747.zip
Pacifist, dumb, not stupid
yes it's the right driver
LINN AKURATE DS, LINN UNIDISC SC,AMPLIS MCINTOSH C300 et MC7106 + RME
53 (edited by Johannes AU 2022-02-02 17:16:58)
When you do the flash, what message can you see at the box?
Start the Flash Update Tool. It displays
the current revision of the ADI-2 DAC
firmware, and whether it needs an update or not. If so, then simply press the
'Update' button. A progress bar will indicate when the flash process is finished
(Verify Ok).
Yes.
Maybe it's best for us to start again, right from the beginning.    The FUT utility is a remarkably easy tool to use, and it seems to me that a basic step is being omitted.
Let's try it again Eric.  Oui?
Curt
Cables:  Red, and White Ones.
Speakers:  Yes
how to put an image (screenshot) here
https://imgbb.com/
57 (edited by Johannes AU 2022-02-02 17:37:28)
This image is done by imgbb.
https://i.ibb.co/vHT7TKY/Screenshot-2022-02-03-at-00-32-27.png
https://ibb.co/T1Tj4fZ
https://ibb.co/HKwcTcB
https://ibb.co/mGQRJD0
https://ibb.co/9cSpmfq
59 (edited by Johannes AU 2022-02-02 17:46:15)
https://i.ibb.co/42fv8qc/RME1.png
https://i.ibb.co/6y9K0Kr/RME2.png
https://i.ibb.co/9NRpn8h/RME3.png
https://i.ibb.co/ckVyKpN/RME4.png
OK, now clear, you flashed the firmware 66/41.
The latest is 78/48 which can be download, use this link:
https://rme-audio.de/downloads/fut_madiface_win.zip
Overwrite the old one and try again.
60 (edited by Curt962 2022-02-02 17:45:48)
Ok Eric.    Let's keep the challenges to minimum today shall we?  smile
With IMGBB, in Viewer Links, select BBCODE FULL.
Copy that link, and then you can post pics here.
Else, it seems you're making progress!  Super!    Now let's install the NEWEST FW as Johannes suggests, and you're GOLDEN!   \ big_smile /
Curt
Speakers:  Yes
Eric, if you update sucessfully, at RME Dac setup page you can see SW Version 48, 01/2022
Curt
I assisted to correct the BBCODE FULL.
It worked, I have the version 48 of 1/2022
Thank you very much for your help
You DID IT Monsignor Eric!
Magnifique!!
Curt
Speakers:  Yes
Hey .... my RME smile
https://i.ibb.co/pXCbmNr/IMG-4706.jpg
Have a nice evening
Have a nice evening
You too Eric, ENJOY the RME !
Magnifique!!
Curt
Fertig und Gut !
Eric, do not forget to download and read the latest manual v3.0
https://www.rme-audio.de/downloads/adi2dacr_e.pdf
