Topic: Help: Flickering lights & can't control volume in TotalMix
I recently travelled with my gear and when connecting it back together there is an issue with the sound that I can't figure out.
I hear sound through the speakers. But in TotalMix the light on all active channels have a strange flickering when I play sound. Also, I can't control the volume. It is fixed no matter if I slide the Main volume controls in TotalMix.
Also, the popup window that says "mismatch detected" comes up all the time. It doesn't matter if I press Yes or No, the problem persists.
I have tried to reload my workspace.
I updated the drivers and flashed the soundcard a month ago. It worked fine both before and after.
The audio interface is Fireface UCX & I use Ableton 11.0.12.
Any advice would be appreciated!
Thank you.
Re: Help: Flickering lights & can't control volume in TotalMix
The problem seemed to be my Elektron Overhub USB hub. When connecting the audio interface directly to the laptop there is no problem.
