Topic: Could Big Sur cause problems using Firewire800>TB adapter dongle??
Hello.
Is a Fireface800 compatible with a 2013 Trashcan MacPro / Big Sur (11.5) when using an Apple TB>FW800 adapter dongle?
I upgraded to Big Sur 11.5 (direct from Sierra), installed 3.41 driver but am not getting the “Allow” dialog in Security and Privacy. I researched the forums, found several informative threads regarding difficulties with Big Sur. This unfortunately is WAY over my head (I don’t know anything about using Terminal) therefore I hired a friend who is very Mac savvy. He spent 4 hours following the various forum threads as well as trying other things. What always happens is;
… the driver installation says “Success”
… no “Allow” dialog appears in Privacy & Settings
… both the RME Settings program icon and the Totalmix program icon are indeed in the Applications folder
… clicking on RME Settings icon “tries” to open but the window flashes and vanishes (too fast to see what it even is)
… clicking on Totalmix icon does open Totalmix, but since the RME Settings did not open, Totalmix doesn’t open a window.
… my Fireface800 doesn’t appear in Mac Audio prefs
My Mac savvy friend thinks the problem may be caused by the Apple TB>Firewire800 adapter used to connect the Fireface800 into the 2013 Trashcan... BUT... the Fireface800 was previously working PERFECTLY with the same MacPro (with Sierra) AND the same Firewire800>TB adapter… in fact it has not even been disconnected since it was running fine with Sierra. Could Big Sur really have done something to make the very same connection path now suddenly NOT work??
If Firewire>TB adapter is definitely known to NOT work with Big Sur I'll have to abandon the FF800 ...(I hope not!)
Thanks in advance for any help.
