Topic: Ray DAT SPDIF ground loop problem
Hi everyone,
I have solved a ground loop problem by utilising a Palmer active DI box.
Signal path RayDAT AES out into a Loudspeaker Management System into the DI Box and then into the speakers.
I would like to use the RAY DAT SPDIF digital out into a drawmer CMC3 Monitor Controller. If I do so, I am plagued by a rather loud hum.
Could you guys please point me in the direction of a capable solution for my problem that does not degrade Sound Quality.
Can DI boxes for SPDIF be used for either analog or digital connections?
Many thanks,
R4Y
