1 (edited by charles_29 2022-04-10 13:42:00)
Topic: Bypassing the conversion entirely / UFX+ as monitor controller
Hi
can I use UFX+ as a monitor controller only? I'd like to use its digitally controlled analogue path in order to achieve this. For example
COMPUTER AUDIO > Mytek DA outputs 1/2 > UFX+ analogue inputs 1/2 > UFX+ monitor outputs
If so, how can I achieve this?
Cheers
K
Re: Bypassing the conversion entirely / UFX+ as monitor controller
AFAIK that's not possible. All analog ins go through a/d-conversion.
It could work if you used the UFX+ as your audio interface then connected the Mytek to UFX+ AES or toslink and then from mytek to your monitors. You just need to assign whichever digital output in totalmix as your monitor Main or Monitor B.
__________________________
Paul Najar
Jaminajar Music Production
www.jaminajar.com
Also thinking that even if your workflow didn’t suit using UFX+ as audio interface you could still do it if the Mytek had a digital IO loop. For this you would send from computer to mytek, then digital from mytek to UFX+ digital in, then UFX+ digital out to Mytek digital in, then mytek analog out to monitors.
In Totalmix you route digital in to digital out and assign whichever digital out as monitor main or monitor B. Your UFX+ monitor controller would now be digital.
Paul Najar
www.jaminajar.com
Thanks. I will try this via ADAT IO on Mytek (there are 2 ADAT ports on a card).
Cheers
K
