Topic: Babyface cable too short, replace cable or get usb 3 extender?
Need to extend the included Babyface pro cable to 6ft. I was going to buy this cable.
StarTech.com 2m USB 2.0 A to Right Angle B Cable Cord - 2 m USB Printer Cable - Right Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB2MR) https://www.amazon.com/dp/B00G2I9W2G/re ā€¦ 9C9F?psc=1
The only reason Iā€™m asking is because I prefer relying on bus power and not sure if this will create any power issues.
Should I go with this or use a usb 3 extension cable?
Re: Babyface cable too short, replace cable or get usb 3 extender?
It will most probably work either way. Personally I would use the original cable with a short USB3 extension.
Thank you very much. Do you have a particular reason for this preference?
The original cable is a very secure fit into the bfp
5 (edited by fieldstu 2022-04-25 18:52:23)
But is the extension connector to the original cable a similar secure fit? smile
ADI2, Digiface, ARC
with a little gaff tape, sure tongue
