Topic: Fireface crashing my PC ?
Hi everyone,
My computer is crashing badly. Fireface seems involved. Could you please recommend me a solution ?
Very best regards smile
Alain
Details :
Windows version:  Windows 10, 10.0, version 2009, build: 19044 (x64)
Windows dir:  C:\WINDOWS
Hardware:  X570 AORUS XTREME, Gigabyte Technology Co., Ltd.
CPU:  AuthenticAMD AMD Ryzen 9 3950X 16-Core Processor 8664, level: 23
Processor count: 32 logical processors, active mask: 4294967295
RAM:  130994,7MB
Dump file              : C:\WINDOWS\Minidump\050522-14140-01.dmp
Date/time              : 05/05/2022 10:20:31
Dump type              : Minidump
Uptime (dd. hh:mm:ss)  : 00d 02:32:30
Machine                :
Build                  : 19041
Architecture           : x64 (64 bit)
CPU count              : 32
BugCheck name          : IRQL_NOT_LESS_OR_EQUAL
BugCheck code          : 0xA
Parameter 1            : 0xFFFFD70D271BB378
Parameter 2            : 0x2
Parameter 3            : 0x0
Parameter 4            : 0xFFFFF8065B07441E
Probably caused by     : fireface_64.sys (no module detected)
Faulting IP            : fireface_64+0x3DCA
Description            :
Product                :
Company                :
Bug check description  : This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This is a software bug.
Analysis               : This is a typical software problem. Most likely this is caused by a bug in a driver.
Re: Fireface crashing my PC ?
I'm having the same issue, constant restarts with fireface400, besides the restarts it works perfectly,
how did u get this information? I want to get a similar log showing me exactly what caused the crash.
https://soundcloud.com/fuzulu
https://soundcloud.com/essio
I purchased the pro version of
https://www.resplendence.com/whocrashed
4 (edited by Tastenhauer 2022-05-23 12:48:47)
I also get the same random crashes on my Fireface 400 leading into a windows blue screen. No fun and pretty annoying when working within Cubase.
I'm on Win10Pro using Cubase12 (had Cubase10 before, but same crash here).
Operation mode in totalmix is switched to DAW. I'm also using the SPDIF's going to my Lexicon PCM92.
