Topic: Multiple talkback groups?
Does anyone know if it is possible to create two different talkback groups in Totalmix?
I´m in desperate need of being able to speak separately with two different headphone groups without both groups receiving the same talkback signal.
I own a Fireface UFX II.
If not, does anyone of you clever guys out there have a smart workaround?
Re: Multiple talkback groups?
No, I don't think so. Comms in TM is pretty limited.
If you're desperate to make this work you can look into the "groups" function in Totalmix. From there you could create a couple of "mute groups", and assuming you've got an ARC remote(?) you can assign two buttons to act as momentary unmutes for an input... But I think you'd need two mics (or at least one mic Y-split to two inputs - probably OK for talkback...) for this to work!! The buttons would also be illuminated when Talkback wasn't engaged, rather than when it was.
Not ideal.
Thats rather clever, but my client thougt it was to big of a hustle so we went for one, single talkback to all.
Thanks for your response anyway!
