Topic: Adi-2 dac et pro sur Linux
Can Adi-2 Dac fs and Adi-2 Pro fs work with a PC on Linux?
And does ASIO (or other powerful equivalent) also exist on Linux?
Thank you in advance:)
Bastien
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → Adi-2 dac et pro sur Linux
Bastien
Bastien
There is no RME driver (be it ASIO or whatever) for Linux available and most likely not even needed,
as for simple playback (and recording) tasks class compliant mode should be sufficient.
Search manuals of both devices for "class compliant".
https://www.rme-audio.de/downloads/adi2dacr_d.pdf
https://www.rme-audio.de/downloads/adi2dacr_e.pdf
https://www.rme-audio.de/downloads/adi2profsr_d.pdf
https://www.rme-audio.de/downloads/adi2profsr_e.pdf
You can choose between two modes: class compliant stereo or multi-channel mode, also explained in the manual.
See also: https://forum.rme-audio.de/viewtopic.php?id=29417
