Topic: ARC USB + Fader Group behaviour
Hello All,
I have setup a 5.1 monitor system by grouping some output faders with the Main fader.
I also have a pair of alt monitors assigned to the Speaker B fader which is linked to the Main fader.
I use an ARC USB to control the monitor levels.
Everything works as expected, all the faders move in sync with each other, until I switch to Speaker B then the faders grouped to the Main do not move when I use the ARC. They do however still move in sync when I use the mouse.
Anyone else experience this behaviour ?
Very frustrating as the surround outputs get out of sync with the Main fader every time I switch to Speaker B.
Totalmix 1.75, Madiface USB, MacOS 12.4 on a 16" MacBook Pro ( M1 Max )
