Topic: Is there any way to set input gain above 65dB via OSC?
Hi, I'd like to set input gain above 65dB via OSC, but it's limited up to 65dB.
Is there any way to do it?
I have TotalMix v1.75 on my Mac, the interface is UCX II.
I send
/2/gain 1.0
but as a result, the gain level is only 65dB.
Is there any way to set the level above 65dB?
I can set it up to 75dB if it's set manually on TotalMix.
Re: Is there any way to set input gain above 65dB via OSC?
https://forum.rme-audio.de/viewtopic.ph … 85#p175885
Hi MC,
Thanks for the info.
I understood why TM couldn't set the gain above 65dB via OSC.
Okay, I'm gonna use switching snapshots/setting the higher gain on the compressor as a workaround.
