1 (edited by juliendeguines 2022-09-27 10:15:32)
Topic: RME UFX Digital Noise Analog Inputs
Hi ,
Since a couple of days ,I have a big digital Noise coming from my Analog Inputs .
It happens when I start my iMac .
It works fine when I restart the UFX .
Could it be an hardware issue ?
Thanks for your help ,
Julien .
iMac i7 3.8ghz 64 Gb RAM / 2020
Mac OS X Monterey 12.3.1
Driver UFX :: 3.27
Firmware : 361
Re: RME UFX Digital Noise Analog Inputs
This could be a power supply or DSP / RAM issue.
Hi Matthias ,
Thanks for your answer .
I’m gonna test the UFX on my MacBook Pro and will let you know .
Matthias , so I tested it this morning . And this not related to my computer . When I started the UFX , I directly had this digital noise on my analog In. Even if my computer is shut down .
So do you think it could be a power supply issue ?
Hi
do the LEDS light up just arbitrarly and play like crazy and you hear noise?
I had this and it was a power supply problem. Power supply failed. After fixing the power supply all worked agin smooth.
Peter
Hi Peter ,
Yes it is exactly my issue . I bought a new power supply .
Thanks ,
Julien.
