Topic: Dropouts with DF AVB, AVB Tool, 12mic
Hi!
I have a setup with 12mic, Digiface AVB, AVB Tool and an Presonus AVB Switch SW5E, clocked by AVB Tool CRF Stream 96k PCM. , Audio is in sync. I used the latest firmware in any device.
I have recorded some channels but got Drop Outs after around 75mins for 1 or 2secs, again one minute later, a big problem while a live concert recording...
Today i have checked everything and still had Drop Outs in recording 1kHz Sine. I disconnected the Presonus Switch and did a direct wiring between DF AVB and AVB Tool and started the recording, still with Drop Outs!
Debugging in Hive:
AECP Unexpected Responses and +1 in "Media Unlocked/Locked".
The AVB Tool is set to 96kHz internal but in Hive the CRF Stream Output says 48kHz, so i am a bit confused. My daw is well clocked to 96k so i was fine with that...
And now?
