Topic: Digiface Ravenna - which RME device could work with it?
Is there an RME device that could work with the new Digiface Ravenna?
Thanks, Stefano
Re: Digiface Ravenna - which RME device could work with it?
No, and it is not planned. Our partner DirectOut provides lots of Ravenna tools and boxes. Else Ravenna ist typically built-in already (for example mixing desks).
You can use devices with Dante with AES67. However, this is limited to 48khz.
Technically it is possible to receive and send AES67 stream with 1722 compliant devices. If they master the stream format. The problem is just getting the devices to connect. To do this, the AVB device would have to implement the Ravenna protocol capabilities.
The simplest solution is to use Dante and AES67.
