Topic: UCX II Static problem
As I feared because of power outages could not have time to check the device in 14 days.
It is only about the direct monitoring with headphones. The bass guitar with the single coil pickup and fully shielded. The cable is good, the grounding in the apartment is also good.
1) UCX 2 plugged into the outlet (tried different ones), the bass is plugged directly into the 3\4 input. Every time i touch metal parts on the bass (bridge, strings, knobs, etc.) As well as some screws on the body of the audiointeface and the back of the interface body is heard a quiet clicking.
- if i connect ucx 2 c using usb cable to a laptop running on battery - the problem does not go away (when i connect the usb cable i hear multiple clicks)
- if i connect the laptop to the socket, the clicks when touching metal parts disappear.
2) Presonus 22vsl (power only through usb) connected to a laptop running on battery - no clicks when touching the parts of the guitar.
- When connecting the laptop to the socket, respectively, also no problems.
If not the fact that presonus 22vsl works without nuances with the laptop from the battery I would have thought that everything is fine. That is, audiobox has no problems with grounding, although the laptop is not connected to the outlet. It turns out that in useсases where ucx 2 is used on the road in standalone mode through duRec or when recording on a battery powered laptop this point is not taken into account?
My understanding is that the ucx 2 uses a adapter with a type C plug. And the laptop is plugged in F socket with a type F plug.
Or the problem is the grounding in the device itself.
Please, check the card in standalone mode without connecting to the PC for similar problems is it possible for someone. Maybe it`s only my device issue. Perhaps there is any solutions how i can get rid of static checks by replacing power cables?
For now i have limited rig to test more clearly. As i remember i had no such moments on motu track 16.
Thank you!
