1 (edited by holehouse 2022-12-30 17:28:01)
Topic: Talkback + OSC
I'm trying to set up an OSC command to toggle ON/OFF the talkback mic to different phones/outputs. I can see there is a command "talkbackSel" but I've not been successful in getting this to do anything (nor do I understand what it's meant to do).
I have currently been successful in passing the /1/mainTalkback command to my main output, and am able to toggle the talkback ON/OFF as hoped. However, the actual talkback signal doesn't pass through to the main output even when it's toggled on.
Any help would be GREATLY appreciated.
Thanks in advance!
Re: Talkback + OSC
talkbackSel equals the Talkback button that every output channel has in the channel's settings panel.
Since when does a Talkback signal pass through a Main output? That would be your studio monitors...and would make no sense...
3 (edited by holehouse 2023-01-02 17:42:23)
Re: Talkback + OSC
If I use the command /1/talkbackSel/1/3 or /1/talkbackSel/3 or just /1/talkbackSel nothing happens. How would I turn off/on the talkback buttons?
