Topic: RME HDSP 9652 + AEB8-O - Change to Line Level Output?
I'm currently using an RME HDSP 9652 with the AEB8-O analog output expansion. The manual says you can switch the output of the AEB to either professional (+4 dBu) or line level (-10dBV), right now it's outputting a professional level signal.
But I need it to go out at line level to a consumer level pre-amp. I've looked through the AEB8-O manual and the HDSP9652 manual on RME's website, and I can't find how to do the switch.
Can anyone advise?
2 (edited by ramses 2023-01-03 08:30:25)
Re: RME HDSP 9652 + AEB8-O - Change to Line Level Output?
Check if you need to set jumpers on the card, see MCs posting here:
https://forum.rme-audio.de/viewtopic.ph … 40#p101240
Alternatively, you need to check these two places:
- TM FX: clicking the tool/wrench symbol of the particular analog output in TM FX
- driver settings: there might be different TABs to look at
Thanks! It was the jumpers! Thankfully, there's right printed on the expansion card the jumper settings to change to go from one or the other, it's all very well organized.
